A client is proposing to retrofit a NEMA 4 pump control enclosure for use in a Class I Div 2 location by field installing a listed purge / pressurization unit from Pentair (Hoffman).
I've normally seen the purged units factory assembled in the panel shop as part of a listed industrial control panels.
Are there any issues with performing field retrofit, assuming the sizing/flowrates are properly calculated in accordance with mfr instructions? Any things to watch out for? As this is Z purge, and based on my read of NFPA 496 I think they are only required to alarm on loss of pressure, and don't need to trip the power supply to the enclosure. Is this correct?
