%Z ?
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Using Bussmann fault current calculator for a 100kva 240/120 1Ø 2.2Z tranny a box pops up selecting "%Z TOL -10% max fault".
What does that mean?
Thanks
jumper
Z is impedance, given on the nameplate of the transformers.
infinity
New Jersey
Journeyman Electrician
Chris is asking about %Z Tolerance with three choices:
-10% Max Fault,
0% no Change
+10%Min Fault.
I have the Android app.
ron
During transformer construction, the manufacturer has a design goal for impedance. ANSI allows for some tolerance in the final result from the design goal # and I think it is 10% plus/minus.
They would put the tested impedance value on the nameplate, but there are times when you only know the goal value, or only an estimated value (many will guess at 2% for small utility XFMRS and 5.75% for larger), so you take a worst case estimate, which would include a -10% impedance adjustment too.
