Gents:
Would appreciate your comments on the following questions:
An electrical pump at a water treatment facility has a local on/off switch. The main switch is located in the neary electrical substation. A permit has been issued to work on the electrical pump. The main swith in the substation was subsequentely isolated by a lock and tag applied by the substation supervisor and a lock and tag applied by the craftsman working on the electrical pump. All in order.
Before work commences on the electrical pump a zero potiential test is required.
Is it acceptable practice to try to start the pump at the local on/off switch to verify zero energy potential or is another electronic test required? If another electrical test is required then why and where should the test be conducted?
Regards,
TVH
Regards,
TVH
