electricalperson
- massachusetts
how does someone do a zero sequence test?
Really? Are you sure they didn't mean fall of potential test?electricalperson said:i was just curious because i heard people talking about doing a zero sequence test to find a problem ...
maybe thats what it ismdshunk said:Really? Are you sure they didn't mean fall of potential test?
Perhaps you're thinking about the zero sequence GFPE mehtod to operate the GFP relay?
Oh, okay. That clears it up.electricalperson said:mentioned by brian john in this thread http://forums.mikeholt.com/showthread.php?t=95584&highlight=sequence
so take a flexible amprobe CT and wrap it around all the feeder conductors? sounds easy..just now i need to buy an amprobe that can take a flexible lead:grin:mdshunk said:Oh, okay. That clears it up.
Put an amprobe around all the hots and the neutral for each feeder. It should read 'zero'. If it doesn't, then current is passing someplace other than the neutral for that feeder.
