Zinc Die Cast Vs. Steel Fittings
With pricing the way it is, can someone point out the advantages of switching electrical fitting buying from zinc fittings to steel fittings?
I've been working with two types for the several weeks, the 3/4 cast aluminum (zinc?) couplings have cracked and even split apart under stress, which never happens with the steel ones.
Also, unless directly on top of it, the phillips tip bit driver always slips before it gets real tight, forceing me to put down my screw gun and use my common tipped Kline reammer to torque down the fittings.
While the steel fitting screw heads fit the bits of my srew gun well enough to torque sufficiently at different angles, they also strip out and the screw heads have sheared off entirely, where the cast aluminum (zinc?) fittings never do this.
Steel is vastly superior to zinc. I'll take a steel fitting any day of the week. The company I work for only buys steel fittings now. What a shame. ;)
Besides quality, the contract document specs.
Roger
For quality go with the steel. I've noticed that manufacturers now a days seem to use screw heads that are designed for about 20 different types of drivers. (OK so I'm exaggerating) but the only driver that fits really well into the screw seems to be the Square drive .
Steel fittings are far superior and traditionally were higher priced. For whatever reason, die cast prices have risen so much, that steel fittings are cheaper at my supplier now.
