allanwalker
New member
I am considering purchasing a commercial building for my business in the state of Washington. The building has the following equipment:
>Zinsco single phase 600 amp main
>Zinsco 4 socket meter panel with 2 each breakers pinned together with 100 stamped on each lever.
>In 2 of the 3 (1000 sq ft) bays there are Zinsco 125 amp breaker panels. In the last bay there is a Square D QO Load Center. No pawer rating noticed.
I have been informed I need to repalce the 2 breaker panels in bay 1 & 2 ( one of which has burn marks on the door and switch cover plate. My question is: should I replace the 600 amp main and 4 socket meter panel as well.
Thank you for your opinion and feed back.
