Re: Zinsco Replacement
That is not the way the process starts (i.e., picking out a new panelboard). You need to get into contact with an electrical contractor in your area. There is a service load calculation to be performed, in order to make sure the new panel will have a sufficient rating for the house. Replacement of a service panel may also require replacement of some portion of the house wiring. That cannot be known until someone who understands the rules takes a look at the existing wiring.
I am in the same situation myself (thing about buying a house that has a Zinsco panel). If all you need is a new panel, the project will not be too expensive. In my case, I am looking at a complete rewiring of the house (by my own choice, not necessarily because any code or rule would have required it).
But let me add that if you have any thoughts about doing the replacement yourself, I would urge you to reconsider. I would also tell you that we are not permitted to assist a do-it-yourself person with electrical installation questions.
