velbek
- California
- Electrician
Hi,
I'm replacing Zinsco sub panels in a 6 unit apartment building. Each panel is 3 wire (2 hots, neutral) and uses the Flex conduit for ground.
My question is if I have continuity between the neutral and panel shell then that means the ground and neutral are bonded near the main disconnect and I should not bond the neutral bus to the shell at the sub panel, right?
Thanks
Thanks
