You can't tap off the SABC for the stove igniter or the hood is that correct? Thank you for your help.
SABC=_ _ branch circuit? small appliance branch circuit?
range is fine because almost no load. Hood no because it often turns into a microwave
Is there a code reference? I am building a house right now that has a chimmney hood, and I tacked it on to the SABC. There is a separate circuit for a micro as well in another area of the kitchen.
The range hood will be cord and plug connected.
Then it must be installed on an individual branch circuit. (See 422.16(B)(4)(5))
Chris
We run on the 05 code, and it doesn't have a 4 or 5.
Nobody on this forum ever does unpermited work LOLAre you getting an inspection?
Correction, I have an 02, what does the 05 say?
