electricalperson
- massachusetts
i said the same things when i first heard it. give it a try and see what happens. whats the worst that can happen? it doesnt work?
That said I am not sure about the wisdom of using nose grease based lubricants in electrical sockets.:grin:
OK Dan, I'm starting to understand more about how it is.
If you say something is not safe then it's not safe.
If you say something is safe then it's safe.
I will remember not to question things in the future. :roll:
has anybody else ever heard about that?
about what?
about my nose grease trick. it sounds pretty stupid but i was told that by somebody that supposedly knows more than i do
I haven't heard of it till now.....people do some pretty creative stuff though. You would be screwed if you were in the desert and it was your turn to supply the product...yor face might be too dry, and you'd get fired:grin:
im pretty sure i know what that means. pretty funnyOn the farm we always used tail grease.
even GOOGLE has no clue what "tail grease" is... so I have to ask :wink:
ok guys this might sound really weird but i learned a trick for this.
its called nose grease. rub the bulb base in the spot between your nostril and your face. that oil will lube up the bulb and be fine
somebody told me this and thought they were kidding
That's what I was taught as well. Have done it for many years, and still do for "crunchy" sounding or sticky sockets. Not a glob, but just enough to moisten your finger and wipe around the base...finger is almost dry by the time you turn the bulb 360 degrees so it takes a couple of trips around the base to spread the Vaseline.The only reason why I through Vaseline up there is....when I first got in the trade my journeyman at the time told me to lube about 40 light bulb sockets
Well I'll be , I actually knew about rubbing your nose and sticking that
finger in a glass of beer to reduce the foam. That tid-bit of information was
passed on to me by my grandfather. Crazy!!
