I'm with Pierre and cpal (and the OP's inspector)....
This seems to come up rather frequently and probably won't stop til 2011......
I don't see how you can void 338.10(B)(4)(A) and 334.80...... As my final justification, the very first sentence of 310.15(B) clearly differentiates between Tables 310.16-310.19 "
, and" Tables 310.20-310.21
as modified by...... The comma and the and being the operative separation. Unless you fall under Tables 310.20 or 310.21 then I don't see how you can modify anything by (B)(1) thru (B)(6).
If that's not the case, then why doesn't 310.15(B) read:
....Table 310.16 through 310.21 as modified by (B)(1) through (B)(6).....???
Interior SE.... 60 Celsius.... 310.16......
Unless you meet 310.20 or 21 then fine. Use 310.15(B)(6)..... But then it wouldn't be interior SE anymore so the point is moot.
