Weatherproof wirenuts question...
zappy
CA.
Are they necessary when connecting the ground wires together? I can see why for CCC. Thank you for your help.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
If you understand why it is necessary for CCC then you should see why for the egc. Loosing a ground is more dangerous then loosing the CCC. Safety here not functionality-- the egc is very important to be kept in tact.
zappy
CA.
So you can use rmc in the ground correct? You can use the conduit as a grd. correct? So should you coat the whole pipe in silicone? I'm not tryin to be a smart a#%. I'm just trying to understand. What about a grd clamp direct buried? Should that connection be dipped in silicone?
LarryFine
Henrico County, VA
Brass and bronze will last much, much longer in the ground than even galvanized (zinc-coated) steel will.
