I quite often hear the term "induction" used to describe phantom voltages on wires. From previous threads I have come to learn that the cause of these phantom voltages is usually a capacitance coupling between wires.
My question is though can a voltage be induced through "induction" between two wires traveling side by side with current in one wire inducing a voltage onto the other wire. I am inclined to say no due to the fact that induction requires a magnetic flux which is defined as a magnetic field through a closed surface. Since these two wires are simply traveling next to each other then there is no closed surface to speak of and thus the magnetic field from the current carrying wire wont produce a magnetic flux onto the other wire.
If this second wire was somehow wrapped several times around the current carrying wire then we would have a closed loop and thus the magnetic field from the current carrying wire would produce a flux through the second wire and induce a voltage. This is also true of what happens when a current carrying wire is run in a metallic conduit, or has a shielding around the cable. Since the conduit or the shielding creates a closed surface, then the magnetic field creates a flux through this surface and thus induceds a voltage.
Is this correct?
Is this correct?
