GG
- Ft.Worth, T.X.
I looked at someones job where they had installed a 200 amp main breaker with 3/0 wire feeding a gutter 80' away.
From the gutter they tapped into the 3/0 and fed 2 panels. Panel A was 150 amps with a #1 wire and Panel B was 200 amps with 1/0 wire. Is this a code violation and if so what is the correct way it should be installed?
Thanks.
Thanks.
