Resistance of wood
EEC
Maryland
I was using a DMM to find resistance of a popsicle stick. Using all the ranges, I could not find any measurement. What will it take to measure this?
mivey
Resistivity
Resistivity
Oven dry wood: 100 trillion -10 quadrillion ohm-meters
Wet wood: 1,000-10,000 ohm-meters
steve66
Illinois
Engineer
I have to ask: Why do you want to find out how much resistance a popsicle stick has?
The applied voltage may have a big difference. It may read very high with a DMM working from a 9 volt battery, while touching 480V with one might give quite a shock.
K8MHZ
It also depends on the wood.
Live pine (as in trees) conducts very well due to the sap and the moisture.
Pine wood for construction is nearly a perfect insulator if dry.
Any wood that is soaking wet, especially with salt water or water with fertilizer n it, is decent conductor. (Actually it's not the wood that is the conductor, it's what the wood contains)
So, you should be able to 'see' a 'perfect' insulator with a DVOM on a dry popsicle stick. Looking at Mivey's specs, above, we could then expect to see 1 to 10 ohms for every mm in length of a wet stick. We should then expect to see 100 to 1000 ohms with the probes 100 mm (4 inches) apart which is easily visible on a regular old DVOM.
To see the true value of a wooden stick you will need a megohmeter as has been mentioned.
K8MHZ
Not with a dry popsicle stick. Kid's don't try this at home, but touching 480 with a dry popsicle stick won't even hurt.
I have even poked around in HV power supplies (1kv and up) with dowel rods and not got zapped. Some of the amps hams poke around in approach 4kv to run the tubes. Before there was plastic, wood was used as an insulator. So was cloth and paper.
steve66
Illinois
Engineer
Yea, I would agree - a dry one wouldn't conduct much at 480. But from the original post, for all we know, it still has the popsicle on it :grin:
jghrist
so to measure the resistance of wood, one would need an ohm meter meter?
ohm-meter is a measure of resistivity, not resistance. Your typical 0.002x0.013x0.1 meter wet popsicle stick with 5,000 ohm-meter resistivity would have an end-to-end resistance of about 19 Mohm.
K8MHZ
So, an ohm-meter is not 'ohms times length'?
If you have a 5000 ohm-meter stick 1/10 of a meter long, would you not have 500 ohms?
What am I missing here??
K8MHZ
Real world test results
Since I didn't have a popsicle stick, I used an incense holder soaked in tap water.
Using a DVOM, it acted like a capacitor. I could see around 1750 ohms for an instant and then infinity. I could also see the effects that lying in water vs. dry had on the discharge rate.
With a 500 volt megger, I saw 3000 ohms at a length of 7 inches, 1500 at a length of 3.5 inches.
I figure this to be about 16,000 ohm-meters.
Now, at 480 volts, 1500 ohms would allow for 320 mA of current. Figure in another 1500 for the body and we would see 170 mA, just under the 'lethal limit' at 7 inches and quite deadly at 3.5 inches.
To me, the above scenario seems very possible and I would rather trust my measured values than one based upon some theory that was way over my head and resulted in a value a few orders of magnitude off what I actually measured.
My uneducated prediction was 500 ohms based upon a 5k ohm-meter sample. I stand by my prediction as my other uneducated opinion is that I created a wet stick of a value of 16,000 ohm-meter using well water and an unknown species of wood covered with ash. The ash will skew the results as it parts of it becomes ionic when dissolved in water.
K8MHZ
When you find out let me know so I can fix this meter socket.:grin:
I don't see anything wrong with it!
:grin:
Great pics! Such a level of craftsmanship is hard to come by now days.
But not all together gone, I fear......
As I type this I am listening (on a scanner) to the fire department working a fire started in the main panel of a home about 10 miles from here.
K8MHZ
Like a capacitor
Like a capacitor
Realize that I did not let the water permeate the sample. I can see how I created a capacitor using wet wood as a conductor and dry wood as the insulator. If the sample was soaked through it would have not only presented less resistance, but would have also presented less reactance as well.
My still uneducated prediction is that the resistance of a totally soaked piece of wood would be measurable with a DVOM with a value of 1000 ohms or less at 7 inches, with no reactance to speak of.
I am not going to soak a perfectly good incense holder over night to find out though. Someone is going to have prove me wrong or just take my uneducated word for it.
rcwilson
Redmond, WA
Resistivity of a material is given in ohm-meters. The resistance of an object, like a wire, is proportional to its length and inversely proportional to the cross section area. More area for current to flow = less resistance. Longer path = more resitance. A 500 kcmil wire has less resistance than a 250 kcmil of the same length.
To make it simple, assume a block of material W x W in width and L long.
Resitance = resitivity in ohm-meter x (length L meters)/(area = W x W)
Look at the units: Ohms = ohms-meter x meter/ (meter x meter) = ohms.
Common misconception about ohm-meters. Many engineers specify ground resitivty incorrectly as "x ohm/meters."
Wood is a good insulator. The performance of a distribution line depends on the insulating value of the wood crossarms.
Rick Christopherson
Just FYI, but in the world of woodworking, there are pin-type moisture meters to determine the moisture content of the wood as part of the drying process. These types of meters are nothing more than calibrated ohmmeters. The conductivity of the wood is a function of the moisture content and the species of wood.
mivey
But not for normal voltage insulation. It has to do with getting the BIL of the pole top at 300 kV or better to reduce lightning problems. With metal crossarms, we have to use higher-rated insulators.
