I am in the process of coming up with a plan for installing a VFD on a 480V 40hp pump which pumps water from a tank. I was planning on using the Allen Bradley Powerflex family and had a couple of questions that came up in my design process.
For this water pump application is there a need to get a 40hp Heavy Duty drive, or will a Normal Duty drive suffice?
Is there a need to order a braking resistor for this type of application? Does the pump cause regen for certain conditions?
What type of drive control mode works best with pumps. Is it better to use sensorless vector or FOC for a pump application?
The speed of the VFD and pump will be controlled by a level in the tank from a transmitter. However is there a minimum speed which you would want to run the VFD/Pump in order to still be able to move water? In other words is there a certain minimum in such an application for a low speed range?
The drive quotes I have show a Filter w/ CM Core. Does anyone know what this is?
I am feeding this drive with a breaker from an MCC. Is there a need to have another breaker or fused disconnect at the drive panel? I will probably put disconnect but wouln't a CB or fuse just be redundant?
