New meter enclosure
goldstar
New Jersey
Electrical Contractor
I'm convinced this only happens in New Jersey. This woman's electric service was in extreme need of an upgrade and the siding guys made it worse (see if you can find the SE cable). The poco insisted that she have her service upgraded. This residence is in a lake community in northern NJ. Years ago people purchased property up here, built their own houses and did their own electrical and plumbing work. I haven't opened this make-shift enclosure yet but it's vinyl siding with an aluminum cover. This is an old 60 amp, 240 volt service. The second meter socket was specifically used for the 30 amp electric water heater where the HO was billed at a reduced rate :
Double meter enclosure (siding guy style)
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Double_meter_2.jpg
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Double_meter_1.jpg
Working meter
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/live_meter.jpg
Blank socket
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/empty_meter_socket.jpg
Poco attachment
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/poco_attachment_1.jpg
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/poco_attachment_2.jpg
Buried SE cable in roof tar
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/SEcable.jpg
First of 3 sub-panels all tapped off the main lugs and unfused.
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/1st_sub_panel.jpg
This one is lucky enough to be in the basement. The main panel is on the 1st floor in a clothes closet. Now, remember I said this was a 60 amp service. All the branch circuit fuses are 30 amps (irrespective of the wire sizes). I'm guessing that they just got tired of the 15 and 20 amp fuses blowing all the time. There's also a 60 amp sub-panel with a 30 amp, 2-pole breaker for the water heater and a 50 amp, 2-pole breaker for the electric range.
This is going to be a fun job if I get it - but it ain't going to be cheap.:D
goldstar
New Jersey
infinity said:
So what's your plan to replace this disaster?
The house really needs a slow burn to the ground but in fairness it's the home of a very nice old lady who's deceased husband did the work. Not sure what I'll find once I remove the aluminum meter cover :roll: but basically a 150 amp service upgrade and a complete re-do of the range/water heater sub-panel in the basement. Anything terminated in the main fuse panel that can't be brought to the new main breaker panel in the basement will be put into a JB. The new SE cable will have to be installed on the siding and wrapped around the gutter in order to get up to the service drop.
McClary's Electrical said:
I believe the service drop is in the soffit, not under the siding. It's hard to tell.
It's actually behind the gutter and under a vinyl facade from what I can tell. I plan to just abandon it if I get the job.
There has definately been illegal work done, as those are not POCO splices
No they're not, but I believe that the poco has never gone up on this roof or attemped to crimp these wires since the 1950's. They'll have to replace the triplex when they come to inspect.
satcom
Just curious why 150amp service and not 200 amp?Not sure what your saving?
It looks like a small home, electric heat? serious AC load ? electric range?
This past fall we did a home with almost the same problem, we did a 125 service 30 ckt panel, and ran the service in PVC cut back the old service cable, and left the mess behind the siding covered the old meter pans, and left the meter pans in place for the owner to cake care of repairs on the siding.
goldstar
New Jersey
It's a small house and a small piece of property. She's not going to be adding anything new like central air or a hot tub. If it weren't for the electric range I'd be installing a 100 amp service. Besides, I have to bend the SE cable around a rain gutter in order to get it up on the house near the drop. It's a lot easier to do with 150 amp SE cable than it is with 200 amp.
goldstar
New Jersey
I plan to do basically the same thing except there's oil heat.
If you look at the poco attachment in this photo http://i87.photobucket.com/albums/k1...tachment_1.jpg the existing meter location is on the side of the house about half way down the roof line. I considered putting up a mast but I would have to drill through the rain gutter to get it up over the roof. The existing interior location happens to be the only place in the basement (under current conditions) where I can locate the new breaker panel.
mcclary's electrical
VA
It's hard to tell, but I think I would set a new meter/ main on the side of the house, not the back, closest to the pole. Then run SER through the crawl. No need to fool with that other mess.
goldstar
New Jersey
If this were a normal house (one that was designed by an architect) I might consider doing that. However, the roof in the front of this photo http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/poco_attachment_1.jpg is a flat roof that used to be over an open front porch. The existing meter location is actually on the side of the house. I was hoping to locate the new meter there in an effort to cover up as much of the opening in the siding as possible. I thought I'd use 2 Arlington meter mounting back plates to cover up the opening.
If I get the job, I'll post the photo of how it turns out.
goldstar
New Jersey
This is the end result of the service upgrade :
New meter enclosure on top of 2 Arlington meter back plates
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Picture001.jpg
Service head and SE cable installed to point of attachment
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Picture002.jpg
Flex PVC installed over SE cable for protection
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Picture003.jpg
I didn't bother showing the breaker panel. We've all seen those;)
augie47
Tennessee
I'm suprised no one thought the SE drop over the roof was an issue
K8MHZ
satcom
Around here SE will get the inspectors red tag out.
The code permits the use of SE an inspector can not flag it unless there is a local law inforce, such as not to be used within 1 mile of tidal waters. he can't just flag it at will.
And that was for AL SE not copper, in some beach towns
