jetlag
- Eatonton, Georgia
I often use a homemade tester to help locate an open circuit, i run an extension cord from a good outlet over to one of the dead outlets or lights. will a bulb tester i then test from hot on the dead circuit to neutral on extension cord . IF dead i know the hot is prob open . So i test from neutral on the dead to hot on the cord to make sure neutral is good. At this point if hot is dead i use a short extension cord with a male plug on each end to back feed current into dead circuit. Some or all of the dead recep or lights usually come back on , most of the time the open circuit is either in first outlet nearest the panel that does not come on . The problem is twice when I have done this it trips the breaker in the panel when i connect my device. How can that be when I plug into an outlet with no hot ? How does the current get back to panel when the hot is open between there. One time when it happened I moved the breaker so it would be on the same leg as the extension cord and the breaker didnt trip . But yesterday i had one would trip no matter which lug the breaker is on. How can that be how does my current from the test cord get by the open hot to get to panel. I still found the open in a lighting outlet, where i said it would be, but the breaker had to stay triped for test. usually i can cut breaker on an off to see what is fed from panel and what needs the back feed. in between those two is the open
