Good luck doing that in FL, trades don't care about each other here. First in is the winner.
I must be lucky then. Rare it is that I don't get there before the ctop.
So, who installs the cord when the DW arrives on the job?I happen to believe a receptacle is best by far. It is a disconnect and you don't have to wait for the plumber to install the dw.
This is were the problem begins. Do we want a plumber doing electric ? Anything goes wrong he will say you did it. He is uninsured for doing electrical. Most times you best just figure in a man to go back for stupid stuff.
My liability stops at the receptacle. What the next person does is not on me. Appliance companies routinely install cords on ranges & dryers. Just because he's "a plumber" does not automatically disqualify him from having insurance.
He can do it quicker anyway, many dishwashers are shipped with the leads sticking out of the hole in the junction box, he doesn't even need to take the cover off much less install a connector.The appliance guy, because he doesn't care if it's listed for use with a cord or not.
In that case, I'd rather hard-wire it, and snap a lock clip on the breaker. Faster and cheaper.Me, if the DW is there in the proper timeframe.
Thanks, that mad me chuckle.
How do you hardwire it if it isn't installed yet?
That's the beauty of the cord. It can be sitting in the garage and still be "wired".
OOPS, made not mad. :roll:
About the furniture or th TV? Not kidding.Cripes I hope you are kidding.
I will pass it if they have a "breaker lock"
This same question came up among regional inspectors last week and 3 that I asked would not pass the "behind the DW outlet".
do you apply that same logic to the disc for the furnace, range, hot water heater, and water pump?
If they're plugged into a receptacle using a cord, yes.
Am I liable for anything someone else plugs into any receptacle?
