encoreman
- Austin, TX
I have a communications shelter that has a "through-the-wall" air conditioner. It is almost like a window air conditioner. Everything "hangs" on the outside of the shelter with a vent and return in the shelter. 210.63 requires a 125-volt, single-phase, outlet within 25 feet of the equipment.
Will an inside receptacle work? It would be within 25 feet. If I had to work on the outside part of the unit, it would probably exceed the 25 feet...
