Originally Posted by
iwire
Well both are 120 volts to ground so the chances of them getting a 240 volt shock without them actually opening a j box or enclosure first are pretty remote.
stickboy1375
With both legs being 180 degrees apart, is it even possible to be hit with a 240v shock?
Here is the OP's inquiry. This is your audience. Where does that ubiquitous 240 volt come from, the how or why. If he gets shocked by 240, that's a line to line source and the neutral is not in the circuit's voltage or current loop. The neutral is a system reference point but otherwise invisible to the line to line 240 volt load.
Guy gets shocked by 240 and wants to know why. Is the voltage source a series connection of two indentical 120 volt windings, in phase, or would you like to continue to baffle the masses with invocations of phase relationships relative to the unapplied, inconsequential, neutral. Somewhere in the explanation, the underlying fact that the secondary winding turns have doubled by adding a second identical coil in series, you are trying to lose this fact. The phase relationship explanation fails to convey this essential information, the underlying physical principle of how the 240 volt is manufactured.
It was not so long ago, the human race spent thousands of years consulting a priest for the times to plant and harvest grains. Predicting eclipses was in the realm of magic. Look closer, do not ignore the circuit foundation principles, and you will see the second, identical, in phase, winding in series.
This is science, not magic or dogma.
