Machiavelli999
Does a power meter display have an electrical clearance?
I am working for a client that has a lot of space issues and I am running into the question of what has a clearance and what doesn't have a clearance a lot. NEC 110.26(A) says "Working space for equipment operating at 600 volts, nominal, or less to ground and likely to require examination, adjustment, servicing, or maintenance while energized shall comply..."
A power meter display is never opened or worked on. Does it need a clearance?
