No and no.
Thanks Guys. Also when you are required to have two ground rods can u run just one #4 exposed to the ground rods, or do you have to have each one seperate.
It's ridiculous they shut my thread down and you can't even spell electric.
What? Are you going to ban me? For what?You trying to get banned? Enough already.
Let's get back on topic and forget about such things.
But I don't like what they did. It was a good topic, lots of views, a few laughs.
When up grading an electrical service on a resident, do yall run a new water pipe ground or use the existing water pipe ground. Also do you run a #4 Conductor to the gas piping system.
If you are relocating the actual service disconnect remember the GEC must come from the SERVICE and not a sub-panel (some exceptions) plus splicing of GECs has limitations.
I know, I felt the same way when they cancelled The Fall Guy.
I agree with no and no,
the question I have to this is what if its an older house with the water pipe grounding at the nearest point, would you now need to run a new grounding wire to within 5' of the water service entrance?
