- Massachusetts
So what? It doesn't define "conduit"
Always a persuasive argument.
but the dictionary does,
As someone said 'so what'.
The only definition that really maters is the definition of the one running the project.
That wasn't intended to be in your face, just to the point. That point actually being what you wrote below, or more accurately, what you can convince the person who pays the bill, either with logic or lawyers.
Like Bob, I fail to see your point or your argument. By the simple fact that the NEC uses the two terms separatly means they recognize a difference between "Conduit" and "Tubing". Trade slang may be that installers see them as one and the same, but the fact is they are not, that's the "So what"So what? It doesn't define "conduit" but the dictionary does, and EMT is conduit per the dictionary definition. Also, the term conduit is used for EMT by Engineer's often. This situation is one where you would need to take all of the info and see what sticks.
Roger
Rigid Metal Conduit
Intermediate Metal Conduit
Electrical Metallic Tubing
In my personal opinion EMT is not 'conduit' unless the specifications state it is.
No it's a raceway. Conduit, tubing, ducts, gutters are all raceways but they are definitely not the same thing.I know, it's tubing but it's tubing used to contain/protect wire, therefore, it's conduit.
Then, in your opinion, what is it? I know, it's tubing but it's tubing used to contain/protect wire, therefore, it's conduit.
I suppose PVC isn't conduit because it's not called PVCC?
Conduit is pipe or tubing used to protect wiring. It doesn't have to have conduit in it's name.
EMT isn't normally used for anything other than conduit. Every electrical supply house in the county stocks EMT that is installed to be used as conduit.
EMT = conduit
Gutters contain wire, do you call them conduits?
Roger
Then all of a sudden you are pulling out EMT and putting in RMC.
EMT = conduit
I have found that discussing the issue without attitude will usually result for the better. My point was that he was more concerned with cash than the install so try to argue your case befor giving up the refund.
Well, no, not exactly. If the planner/engineer/etc stray from the common meanings of trade language, they can't get upset when the trade doesn't do what they want.
And I'm sure they missed a lot of words. A road , a train track, a flight path, etc... could be refered to as conduits from point A to point B, we need to forget the dictionarys of the world and focus on the NEC meaning.According to Merriam - Webster gutters could be called conduits. Their definition of conduit also includes the word "tube".
Unless they are being used for something in particular.I still stand by the fact that both conduit and tubing are too general of terms to use and expect someone to know exactly what you are talking about.
Bingo, and I would think that the Engineer mentioned in the OP was working as an Electrical Engineer, which would be a strong indicator of what he/she was talking about in using either word be it Tubing or Conduit.In combination with other words they become more specific such as Electrical Metallic Tubing or Rigid Metal Conduit.
But conduit has a specific meaning at least to the NFPA / NEC / UL / Manufacturers.
In my opinion the OP should have sent an RFI before installation (or bidding) asking for clarification.
I send a lot of RFIs, I cover my ass very well.
Unless they are being used for something in particular. Bingo, and I would think that the Engineer mentioned in the OP was working as an Electrical Engineer, which would be a strong indicator of what he/she was talking about in using either word be it Tubing or Conduit.
I will admitt that expecting a credit for using EMT is bogus, but that probably want do much for the dispute.
Roger
They have done their job of designing, if specifications are not met then their design was not followed and they are not liable for something they did not design. It is the GC and or owner that should be interested in having it done as designed
They are liable if he let's it slide.
If the owner accepts a credit for the deficiency, the Engineer is off the hook. If the owner does not accept, the Engineer may have no choice but have them rip it out.
The owner is paying for a highly specified, safe design with a stamp on it.
I don't think that is the case here. Like I said before, piss-pour documents.
You get what you pay for.
Don't take this wrong but, you don't deal with many large jobs do you. As Cd starts off with "if the owner accepts a credit" this is very common and many times part of run of the mill VEing. The engineers design is not set in stone if the owner (the engineers customer) is trying to save money or in this case, the design was not followed. The owner can accept the credit if they choose to or they can be stuborn and make the contractors give them what they wanted.Does any credit involved matter. If engineer accepts changes to what was originally then he/she effectively made changes to the specification didn't they? Why would that get them off the hook if something becomes of it later?
Its a mute point he doesnt have a problem with the emt if all he wants is money back. if he did not want emt he would ask for replacement, so i would chalenge him on it.
