Br4nd0n
- Indianapolis, IN, USA
I have a 6" vibrating electric bell that is old and all "nameplate" info has deteriated. I think it's an AC bell, but I'm sure someone here can verify for me.
The bell has a black and red leads which are each connected to two separate coils and then together at the top of a small contact block which appears to do nothing other than joint these wires. One side before the contact block has a small device wired in series which I believe to be a diode. The resistance across the leads is 45K ohms and can only be read one direction.
When the plunger is activated by hand, there are no contacts that open to break the circuit which I think is required by a DC bell.
Based on this, it seems to me that this bell requires AC. Am I right to think that the alternating current in conjunction with the diode creates the wanted "chatter" of the plunger against the bell? If so, should I assume it's good ol' 120V? Searching the web, 12/24v DC and 120V AC seems to be the availability of this type of bell.
