You know these adaptors are everywhere and it looks like a lot of them are made by the same manufacturer and sold by many distributors.They are UL listed to be used in PVC conduit systems and I believe the intent is to be used as a terminal fitting,in other words at a enclosure where the PVC has to be adapted to a locknut or screw into a hub or PVC fitting. If they are used as a transistion fitting(ie: from underground PVC to aboveground RMC) I'm not sure they are listed for that use and may not get by the inspectors in that application.Whats your thoughts on this?
www.cooperindustries.com/...fittings/pvc/non-metallic_pvcconduitfitt..
dick
dick
