If use 110 v for a 220 v heater i will get 1/4 the heat ?
Heat is energy. Energy is expressed/measured in Joules. At least it is with SI units.How do you measure heat? Are you talking wattage?
Simple. One volt times one amp for one second is a joule.
I'm working on getting you guys converted!!
Interesting results, eh?Speaking of conversion, this website http://www.unitconversion.org/power/watts-to-joules-per-second-conversion.html gives you a convenient watt-seconds to Joules converter as well as the advertised watts to Joules/second converter. You type in a number in either box and it shows up in both boxes.
Not conventional. It just is.Accepted that conventionally heat is energy.
We Brits gave up on the BTU, British Thermal Unit, decades ago. The amount of energy required to heat a pound of water by one degF....But the output rating of a heat producing appliance is usually specified as the power of that appliance, whether in watts or in BTU/Hour. (The BTU is of course a unit of energy and not power.)
I had some experience with that.Good luck with that.
They tried forcing it on us in the 1970s and that pretty much failed.
"Accepted that conventionally heat is energy."
