Was looking for a cheap way to hook up a furnace to a small 2200watt gen. No transfer switch. Just chord and plug.
figured I could use a double pole/double throw center off toggle switch. would do this at the furnace disconect switch on the unit. I would use 18" piece of SO/Sj with a male chord cap. That way it would accept the female end of the extension chord from gen. By using double pole/ double throw toggle it would isolate both seperate both grounded and ungrounded conductors from each other. Also preventing the male chord cap from ever being energized(not possible). I dont see any problem with this as far as the code goes. Does any one else? Thanks
