Cow
- Eastern Oregon
- Electrician
Dug one of these up once,
Luckily the Maw Bell locator said it wasn't there
Whoa! I couldn't imagine splicing all the pairs back together on that one!!!
WOW- how many pairs in that thing
To locate a private line you first must know if there is a private line there to locate. Utilities don't always have accurate records, but at least have records to tell them if there is something in the general area, and then send someone out to mark it if there is something there. Private lines seldom have any kind of record and we rely on assumptions to some extent. Like if there is a separate building on a property with electric power - then at very least there must be at least one electric line somewhere supplying it, unless the energy is derived from within.I am unsure of the laws, however the liability of hitting a line is too high to consider not having your locates done. I used to be a locator and I have seen what can happen. Even a having a "private locate" which you would pay for is worth it. For instance, a company did not have locates done in a parking lot they were boring a new line through. They hit one of the electrical feeds for the parking lot lights and the cost of down-time, the repair of the line and then having to get and pay for the locate anyway was quite steep. Luckily no one was hurt in that one, but the $500 locate would have saved them thousands of dollars.
There is just far too much evidence of the property damage and injuries that can occur from failing to have locates done. If it not law, it definitely should be.
... It's just that they have a really nice lawn and I don't want to piss them off.
There is an ongoing legal case here involving a Verizon sub-contractor who was boring under streets in a housing development and hit a gas main. One unit was totally destroyed and I believe two firemen were injured. The owner of the company pled guilty before trial as the evidence was stacked against him and is facing jail time. Now he's withdrawing his guilty plea because the tech from the locating company is now admitting that someone from the homeowners association chased him away before he could finish because "they didn't like all those marks on their streets".
-Hal
-Hal
I'm seeing a lot of stories, but very few answers to the question.
Do you "call before you dig" on every single house that you drive ground rods at?
i haven't in the past. i've also been lucky.
here' why.... the dig alert folks will come and tag the street
out at the curb, so i know where the utilities enter the property
line.
The only way they can get away with not locating beyond the street is if it is considered a private line after that point.
To locate a private line you first must know if there is a private line there to locate. Utilities don't always have accurate records, but at least have records to tell them if there is something in the general area...
That usually isn't going to happen with electric lines if the meter is on the structure served, or water lines with meters on structure served. Also isn't going to happen with any line that serves more than one customer, property, etc. Those are not private lines if they serve more than the property they are located on.
http://www.cnn.com/video/?hpt=hp_t2#/video/us/2013/04/02/sotvo-oil-driveway.from-youtube-drew-barnes
Here is a link to an Exxon-Mobile pipe break.
Notice it is bubbling out right next to the cable box.
Ground rod? Trenching?
Think they called before they dug? :ashamed:
