huskerpower
- Lincoln, NE
All-
I have been a frequent user of the site and thank you all for your help. I've ran across a problem I haven't been able to solve and wanted to seek some advice.
I have a customer who is needing to put a sump pump into an Egress window to deal with a high water table when it rains. From the sump pit to the top of the window well, the distance is almost 8 feet. What are my options here to get 120 volt power to this pump? Obviously the majority of these pumps are hardwired and I believe cutting the plug end off and hard wiring it into a weatherproof box is a UL violation. Is it possible to install a GFCI in the well as long as it's 12" off from the base of the window well? What about using a single receptacle and remote GFCI? I've got a call into my local inspector, but haven't heard back and wanted to check with the community of experts. Any help would be appreciated!
