Does anyone offer a reasonably priced heat trace controller that will:
1. Turn off the heat trace when its warm enough its not needed.
2. Offer Ground fault Protection for Equipment as required by the NEC.
3. Give an alarm contact that closes when something is wrong. (IE: power lost, GFPE tripped, heat trace open, etc.) Basically, a just a warning before the pipe freezes.
This is for a simple water pipe freeze protection. So far searching the internet I've found chromalox and Raychem/Pentair, but I think those are going to be really expensive. It doesn't seem like this should cost $3000 for a simple heat trace controller.
