starsandstripes
- SE Michigan
The lights and garage door opener are functioning OK in a customer's detached garage. The outlets in the garage are not GFCI protected. Voltage readings at outlets are: line to neutral 115 volts, line to ground 26 volts, ground to neutral 26 volts. Readings taken with a Fluke T5. The garage is fed underground from a 100 amp panel in the house. I know I am not getting a good ground and I am inclined to tell the customer the cable to the garage is failing and should be replaced. I think if I tried to install a GFCI it would probably trip.I would appreciate other opinions on this.
