PEN
New member
- Naples, Fl
I want to know where I can find an article in the 2011 NEC that covers single family dwelling floating dock wiring.
I know commentary from the HB has little value here but below is the definition of "building" from Art. 100 followed by the commentary in the 2014 handbook. If you believe that a private dock fits this definition then 553 would apply.
A dock is not a building....
BUILDING. Building shall mean any one- and two-familydwelling or portion thereof, including townhouses, that is used,or designed or intended to be used for human habitation, forliving, sleeping, cooking or eating purposes, or any combinationthereof, and shall include accessory structures thereto.
Here is the residential building code definition
I believe that this only supports the notion that a dock is a floating building.
BUILDING. Building shall mean any one and
two-family dwelling or portion thereof, including townhouses, that is
used, or designed or intended to be used for human habitation,
for living, sleeping, cooking or eating purposes, or any
combination thereof, and shall include accessory structures
thereto.
ACCESSORY STRUCTURE. A structure not greater than
3,000 square feet in floor area, and not over two stories
in height, the use of which is customarily accessory to
and incidental to that of the dwelling(s) and which is located
on the same lot
I don't know where I stand on this one.:?
If we read it as you are suggesting and I place a light pole (a structure) on a residential property that it suddenly becomes a building? :huh:
....we have had to install float switches (on the land side of the feed) to trip a shunt trip breaker to disconnect the power to the floating dock, if the water gets above a certain point....
I knew I had seen this somewhere. Took some looking but here it is. Not sure it applies in this case specifically because it is referred to as service equipment.
682. 11 Location of Service Equipment
On land, the service equipment for floating structures and submersible
electrical equipment shall be located no closer than
1.5 m (5 ft) horizontally from the shoreline and live parts shall
be elevated a minimum of 300 mm (12 in.) above the electrical
datum plane. Service equipment shall disconnect when
the water level reaches the height of the established electrical
datum plane.
It is a "floating building" and also happens to contain a dwelling unit. Unless it is a "watercraft", on board wiring is outside the scope of NEC. If it is a watercraft there are other standards that can apply - not all that familiar with them so can't tell you what they are though. Shore power for such things is covered by NEC though.
I did not read 553 at all, but yes I still believe it is covered by NEC and that 553 is a place that may need to be looked at.I am confused by your post. Are you supporting that a dock is a floating building and therefore 553 applies?
