Your GFCI tester relies on an internal connection to the ground/EGC pin to carry the test current. Your ungrounded receptacle cannot supply that.I installed a new type gfci outlet on a two wire circuit in a residence and it won't trip . I had a old style gfci and it will trip with a gfci tester. Any ideas why the new gfci won't trip ?
I agree, the onboard test button is the only way to test a two wire connected GFCI.Your GFCI tester relies on an internal connection to the ground/EGC pin to carry the test current. Your ungrounded receptacle cannot supply that.
Use the test button built into the receptacle instead.
I would suspect the bootleg connection too.Unless I'm behind the curve, GFCI testers will not trip a GFCI installed on a two-wire circuit.
I have no idea why the old one tripped. (The old one did not have the neutral bootlegged to the ground terminal, did it?)
I've heard and read many times that the only UL recognized test method for my GFCI receptacle is the on board test button, but I have not been able to locate the UL statement, or section number.
if someone is able to describe the UL section I would appreciate it.
Thank You
M Hanson
Thank You
M Hanson
Sorry Bob, but he asked for UL documentation, you gave him the NEC section that indirectly points us back to what he was asking for.NEC 110.3(B) and the instructions that come with the device.
LMAO
I gave them a legitimate code cite for it.
I don't believe there will be any available UL document that spells this out.
But apparently you do so how about posting it?
I'm sure the test button is the only sanctioned test because it is safe to run. But, to me, it does not feel very much like an independent test.
I can think of a real test that does not depend on the test button, but I am not sure what you would have to do to make it safe to perform. If you ran a wire from a real (panel) ground through a 10K ohm resistor to the hot side of the protected outlet, then that should draw about 12 mA in an unbalanced manner. If that does not trip the GFCI then it is defective.
Thank you, I appreciate the input.
I am aware of NEC 110.3 (B)
In reviewing previous posts I see UL being referenced as the authority on field testing. However the posts are not providing a UL reference number.
I would simply like to substantiate the claim.
Thank you again
M Hanson
But if you really look into how the test button does it's job you will find it is a reliable, real test of the unit. It does not simply drop out the relay, it shunts current via a resister around the CTs causing an current imbalance resulting in a trip it the device if working.
I have used a 3 prong adapter and connected the grounding tab to a known good ground, usually a pipe in the kitchen, but sometimes all the way back to the panel. Then I plug an ice cube type GFCI tester in the adapter. So far, it's worked the handful of times I have used it.
As far as safe, I thought so for electricians, but maybe not for the general public.
Testing GFCIs on nongrounding circuits.
Testers should not be used to test GFCIs installed as replacements for two-wire receptacles on nongrounding circuits. By design, GFCI testers will not test a GFCI protecting a 2-wire circuit and can expose the user to a potential shock.
The test button integral to the GFCI applies the test current between hot and neutral. This is not the case with GFCI testers; the test current in these devices is applied between hot and the equipment ground. Therefore, if there is no equipment ground, no test current will flow. If there are any exposed metal parts connected to the receptacle grounding contact (such as a metal face plate or a weatherproof cover), they will be energized by the test device. Since some of the test devices apply up to a 30mA test current; using such a tester on a 2-wire circuit while touching a metal cover plate could result in an uncomfortable shock.
Keys to testing GFCIs.
* Use the GFCI integral test button.
* Check for line-load reversal using the GFCI integral test button supplemented with a lamp or appliance.
* Be sure that any GFCI tester used is listed to the current UL standard.
* Do not use GFCI testers on two-wire nongrounding circuits.
LMAO
LMAO
You can go through all kinds of acrobatics to perform tests but it is unnecessary, the following is an excerpt from this EC&M article
Roger
I don't understand the point of your question, you could miss an outlet in any testing scenario no matter how complicated you make it.So how do you satisfy yourself that you didn't inadvertently miss an outlet somehow if you can't test them all?
