Industrial raised cover.Mulberry is a company. What is a Mulberry cover?
I would say you can do as described. I have done it and seen it many times. The only objection could be since the plate sticks out past the box a kid or someone might catch themselves on it. Having said that mulberry covers look a lot better.Could I use plaster rings and standard plastic covers without sheetrock up and pass inspection or do I need to use a mulberry cover?
Sent from my SM-G965U using Tapatalk
Even when everything you are installing is exposed/surface mounted?In our area you must have the rough-in inspection before you can trim it out
