Buchanan1
- Vernon BC Canada
The wind turbine is operational again...or I should clarify that we've installed a new (the third one) 6 kw Aurora inverter.
In addition, the contractor has implemented a braking function so that when the controller senses either a certain RPM, or voltage, or windspeed, or turbine head temperature, it will apply the 10 kw dumpload in parallel with turbine output, thus loading the turbine and dissipating excess energy.
By the way, the last data in the broken 6 kw inverter was 460, well within the safety zone, so it's up to Power One to figure out why it's broken. There had, in the other one, been a missing MPPT field, but not the last inverter.
My apologies the contractor wasn't able to get on this site to answer each person's comment, but I did send all comments to him to read.
From midnight to early this morning, we've produced 16 kw.
Seems to be working well.
Thank you for the suggestions!
