kwired
Electron manager
- NE Nebraska
What is the chance that all three will be on at the same time within a random 15 minute interval? Assume a 50% duty cycle. My 2.5 pulls about 20A.
If there's a power failure they will be all be on for a while but that happens rarely.
When you hit the max demand designed area, say a day where temp reaches 100 deg F or more, I would expect to see all three running nearly 100% of the time during the worst part of the day. I would also expect to see similar on the other end of things. Electric heating would run near 100% of the time if temps reach designed or even fall below designed low temps. If units run short cycles when at these extremes then those units are going to be oversized in most cases and usually will not be as efficient for the application as a properly sized unit would be either.
