K8MHZ
- Electrician
This has probably been covered before, if so, my apologies.
In a nutshell, a church as 240 volts (measured) in the panel. Air make up and range hood motors are labeled 208.
EC says it's no problem, happens all the time. I trust that it happens all the time, it's the 'no problem' thing I am suspect of.
For one thing, if a motor is rated at 17.5 amps 208 volts, won't it draw MORE amps at 240? EC says Ohm's law says more volts means less amps. I tried to show him the math, but he was really, really busy and had other things going.
It's no skin off my nose if the 240 is a problem, I am just curious. This particular EC does a lot of stuff like this so I am thinking things will work. It just makes me wonder why a 208 volt motor that can run fine on 240 volts also would not be marked as such.
Thanks in advance for answers.
