- Chapel Hill, NC
- Retired Electrical Contractor
I am looking for feedback on this article. As I read the article no bonding is necessary on a gas pipe if, for instance, the only gas appliance is a water heater.
It appears that the cmp inadvertently or not, defined likely to be energized. What do you all think
(B) Other Metal Piping. If installed in, or attached to, a building or structure, a metal piping system(s), including gas piping, that is likely to become energized shall be bonded to any of the following:
(1) Equipment grounding conductor for the circuit that is likely to energize the piping system
(2) Service equipment enclosure
(3) Grounded conductor at the service
(4) Grounding electrode conductor, if of sufficient size
(5) One or more grounding electrodes used The bonding conductor(s) or jumper(s) shall be sized in accordance with 250.122, using the rating of the circuit that is likely to energize the piping system(s). The points of attachment of the bonding jumper(s) shall be accessible.
