See posts 2 and 3.Yes, but do I really need those box extensions for 1/8"?
If boxes set for 1/2", is it possible they'd only be recessed 1/8"?If the 5/8" drywall is installed correctly, your boxes will be 1/4" recessed.
If it's really recessed that much you might use one of these metal extenders, but the cost is going to add up if you have a lot of them:If the 5/8" drywall is installed correctly, your boxes will be 1/4" recessed. 98% of drywallers install the drywall incorrectly in which case expect your boxes to be recessed 5/8". Expect to use a lot of box extenders.
When plastic boxes are installed with 1/2" drywall they are recessed 1/8" if the drywall is properly installed. 1/8" is halfway between the 1/4" max recess allowed by NEC and flush giving the maximum allowable error in installation. If the boxes were designed to be flush, they would occasionally be above the drywall when installed incorrectly. Above the drywall is very bad.
Are you saying plastic boxes are specifically designed to not be installed flush with finish? Or is this personal preference?If the boxes were designed to be flush
What about the round light boxes?
What notch?Just ask them to cut the drywall tight to the box size and get some longer screws.
Using that notch on the side of the box never worked well for me.
