roger3829
- Torrington, CT
iwire said:Dennis 200.7(A) says you can only use white for the grounded conductor, then 200.7(C)(2) says you can use the white for the supply to the switch.
200.7(c)(2) says...... it can be used to supply the switch but not as a return conductor from the switch to the switched outlet.
Since the wire is not connected to the switched outlet, but rather is supplying power to another switch (traveler) I don't see how this would be a violation
