The rule does not govern the dryer itself; it governs the receptacle outlet. An existing 3-wire outlet need not be replaced with a 4-wire outlet. I am sure that is what you meant to say.pierre said:250.140 is the reference. The exception permits existing (existing before the code rule change) dryers to be of the 3-wire type.
Mine has 240 volt heating element and I just looked a number of online wiring diagrams that all showed 240 volt heating elements and 120 volt motors and controls.A lot of people don't know that the dryer is 2 110v c1rciuts. One for the 110v motor and one for the heating element.
The change to delete the 3 wire circuit and require the 4 wire one took at least 5 code cycles. In all of the proposals and comments, there was not one documented case of a shock or other problem caused by the use of a 3 wire circuit.Then one day someone touched the dryer while the other hand was submersed in the laundry sink water and said, # * @ # .
I had one case in my over 20 years.What happend was a defective range surface mount outlet.It was not making a good connection to the cord netral.Luckily the lady that was pregnant at the time was ok,had her or the baby been hurt a company brand name that starts with E would been in court.Give you all a hint it started during world war 2don_resqcapt19 said:chicar,
Don
chicar said:Received a service call. Lady would get shocked when hand in sink and touch microwave while on. Removed three prong receptical from wall. Someone jumpered the grounding screw to the grounded screw just to fool the inspector. I removed the jumper wire,installed g.f.c.i.,install the sticker,done.
That was investigated by Bennie, and he could find no evidence that the use of a single wire for both the grounding and grounded conductor had anything to do with WW2.Give you all a hint it started during world war 2
