- Lockport, IL
- Retired Electrical Engineer
Speakers are to be installed under an auditorium stage. A person sitting in the front row could (barely) see the speakers through metal grills. Each grill is installed in an opening in the wooden, vertical face at the front of the stage. To get at the speaker (repair, replace, clean, etc.), you would use a screwdriver to remove the grill. Each speaker has a powered amplifier that needs 120 volt power via a plug and cord connection. A standard duplex receptacle will be installed behind each speaker.
Question 1: Does this arrangement create a violation of 400.8(5), in that the amplifier?s power cord will be underneath the stage, and accessible only by removing the grill? That is, would the cord be considered ?concealed??
Question 2: If the answer to #1 is yes, would it matter if each receptacle is installed next to the speaker, instead of behind it, so that the amplifier?s power cord would be (barely) visible through the grill?
