kwired
Electron manager
- NE Nebraska
Any untraine person can do worse then that because they don't know any better. NEC is not supposed to be about protecting the non qualified if they are attempting electrical work.The reason for a neutral in every switch box is for safety. As I remember it's meant to prevent end users from replacing a standard switch with a device that requires a neutral. What ends up happening is they tie the neutral to the ground because they don't know any better. That's a no - no.
If there is a component that places current on a grounded conductor there is good reason to use a grounded conductor and not an equipment grounding conductor.The only reason I can see a N wire at the switch is for the cable industry to sell us cable with more wires in it to make more money.
That right there is the biggest issue here, NFPA vs UL, and we get stuck with whatever compromise was made.Actually the problem is the sensor device may be listed as using the EGC as a noodle. The rule was made so UL would quit listing these devices.
