Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
I found it. I guess it was re-submitted by the original submitter as a comment on the CMP ruling.
Ballot Not Returned: 1 Gill, C.
___________________________________________________
17-50 Log #464 NEC-P17
Final Action: Accept in Principle
(424.19)
(424.19)
________________________________________________________
Submitter:
Dan Leaf, Seneca, SC
Comment on Proposal No:
17-32
Recommendation:
Accept proposal revised:
An approved means shall be provided to that simultaneously disconnects
all ungrounded conductors of the circuit for the heater, motor controller(s),
and supplementary overcurrent device(s) from all fixed electric space heating
equipment from all ungrounded conductors.
Substantiation:
Since the panel declined to limit disconnecting means to
switches and circuit breakers, they should be specifically required to be
approved. Lugs, terminals, and wire connectors are means of disconnection
which may not be suitable. Ungrounded conductors should be specifically
required to be simultaneously disconnected, as required in many code sections.
Panel Meeting Action: Accept in Principle
Revise the first sentence of 424.19 to read as follows:
Means shall be provided to simultaneously disconnect the heater, motor
controller(s), and supplementary overcurrent protective device(s) of all fixed
electric space-heating equipment from all ungrounded conductors.
Panel Statement:
The revised language more clearly presents the requirement
and meets the intent of the submitter.
Number Eligible to Vote: 13
Ballot Results:
Ballot Results:
Affirmative: 12
