charlie
- Indianapolis
No, we run the system multi-grounded neutral (MGN) to the service point if it is a grounded system. If it is an ungrounded system, you are not supposed to get the MGN. The MGN is not a grounding electrode and is not normally provided on an ungrounded system. Besides, it would be of no value to provide it to the building since it is not a current return path.Doesn't the POCO run the system neutral/EGC to the service equipment for grounding even if the secondary system itself is not bonded?
