5 conductor 4wire plus ground/messenger needed overhead building feeders
mopowr steve
NW Ohio
Electrical contractor
What about tray cable, lashed to a messenger? If it's sunlight resistant is there a problem, or are we back to the listsings issue (type TC is only listed for use in tray )
Nice idea! As long as you use multi listed tray cable with sunlight resistance. I've used some before that was also underground listed.
don_resqcapt19
Illinois
retired electrician
I don't think I have ever installed any tray cable that was not sunlight resistant and rated for direct burial.
336.10(4) specifically permits TC to be used on a messenger wire as does Table 396.10(A).
Smart $
Esteemed Member
Ohio
If he's trying to get away from using a messenger wire, what about using an Article 400 [extra?] hard usage cord... would it need a messenger wire?
Keep in mind that a steel messenger wire is desirable for long spans. I don't believe OP specified the span distance(s).
don_resqcapt19
Illinois
retired electrician
I don't see this application as a permitted use as shown in 400.7, but I also don't see it as a prohibited use in 400.8
There was no span distance specified, but unless the span is very short, there will have to be supports between the two structures.
Smart $
Esteemed Member
Ohio
So he clearly cannot and can, respectively... :blink:
"Very short" is quite vague. There doesn't appear to be any way to determine the maximum distance between supports under the NEC.
xformer
Dallas, Tx
Master Electrician
Underground is not a option. Im thinking muticonductor MC or service entrance cable. That transformer idea is quite creative. What a great forum.
May I ask why underground is not an option? And since we are talking silos here, do we need Class 2 equipment?
spedobill
st paul, mn
and the final pre-inspection answer IS
I like Cow's idea on a transformer. That got me thinking............With 480v 3p available....I'm going to run a 3phase 480v 3wire overhead feeder, using messenger as a equipment ground.......tri-plex should work.....i'm hoping a unaltered multiwire overhead assembly will fly. Drop it down to a 480v disconnect.......thru a transformer.......into a 250v service disconnect and feed my panel.
My main issue with this project was finding a 5 conductor overhead wire assembly.
I thank you all for your input.
