ampacities of branch ckts?
thetacon
I am trying to understand the ampacities of 15 and 20 amp ckts in 'romex'. I have had more than one boss tell me that i could not put more than 16 amps on a 20 amp circuit . the logic being 20x .80% derating for continuous duty equals 16 amps.
When i calculate it i use art 334.8 which allows me to derate using the 90 degree column of table; 310.16 unless it end up being higher than the 60 degree column which i must than use it for derating purposes.
table 310.16 puts 12 awg at 25 amps in the 60 degree column .
25 x .80% = 20 amps.
i know that 240.4(d) requires a 20 amp breaker for 12 awg. and as far as i know you do not derate breakers
so is there a step that i am missing to get down to 16 amps or have i had some mistaken bosses, and the allowable ampacity is 20 amps
thanks
infinity
New Jersey
Journeyman Electrician
The 80% is for a continuous load. That doesn't mean that a multi outlet circuit can't be loaded to a full 20 amps. Look at 210.19(A)(1) and (2).
Jomaul
Ocala, Fl
look at table 210.24. Your Bosses may be refering to Table 210.21 (B) (2), which shows the recpt being derated by 80%. But that is for the load on the recpt. and not the the ckrt. suppling the recpt.
haskindm
Maryland
This is a common oversimpification of the NEC. Many people say that no circuit may be loaded to more than 80% of its rated capacity. This is NOT in the NEC. A CONTINUOUS LOAD may not exceed 80% of the circuits capacity (ampacity). If the load is not expected to last 3-hour or more, it is not continuous and the circuit may be loaded 100%. Also keep in mind the restrictions of 210.23 and 210.24 which prohibits the rating of any ONE cord & plug connected piece of equipment shall not exceed 80% of the branch circuit ampere rating. The NEC is not simple and any attempt to make it simple often leads to confusion.
haskindm
Maryland
No, a continuous load must be calculated at 125%. A 20-amp continuous load would be calcuated as 25-amps, which would require a 25-amp breaker and #10 romex (NM cable).
Sass5150
1) No. Continuos load of 16 amps on a 20 amp. circuit.
2)There is nothing in a dwelling unit that would be classified as a continuos load. I debated that with an engineer/instructor. Take for example a base board heater. I know and you know it will be on all night long but it is "Thermatically controlled" and therefore not considered continuos.Same theory for other stuff you can think of.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
sparky59 said:
so...a hard wired continous load of 20 amps would be ok on a 20 amp breaker and #12 wire?
The 80% is not a derating factor of the 90C column of #12 but rather an 80% reduction of the circuit breaker. 20 amp breaker means 16 amp load.
steve66
Illinois
Engineer
A baseboard heater would be a continuous load, thermostat or not because it can be expected to run all night. 424.3(B).
Steve
steve66
Illinois
Engineer
No, but a hard wired non-continuous load of 20 amps would be OK.
Steve
haskindm
Maryland
A thermostatically controlled baseboard heater is NOT a continuous load because it will NOT usually run all night. The thermostat will cycle the unit on and off. HOWEVER 424.3(B) requires that the conductors and overcurrent devices for electric space heating be sized at 125% of the total load. So same difference.
Sass5150
I had to mention baseboard heaters didn't I...Thanks for the code article Steve as well as the input from the others.
...Bob
What if that ckt was to a motor..Wouldn't 12AWG, NM cable be ok,per 240.4(d)(g)? and the breaker could be as high as 50AMP?
Dennis Alwon
Chapel Hill, NC
Sure but I think they are talking about the general rule not the exceptions to the rule. A/C would be the same as well as others mentioned in Table 240.4(G)..
Thanks...cause the more i read the more i don't feel like i know anything
Dennis Alwon
Chapel Hill, NC
Here -- stare at this for awhile. It will make you feel better
47b7d824b3127cce8521c1195c3600000026100UaNmbRs1Ys
By the way this is not an animation but an optical illusion​
