I have no problem with arc fault protection. If I ever see one.
I just feel this was shoved down our throats with very little testing for actually making it work.
How exactly do you detect an arc 5 feet away from the connection point? I know enough about electricity to know you can't. You can compare the current going in VS the current coming back (GFCI anyone?), you can even measure a lot of other things, but I still can't figure how can you measure an arc? If there was to be a true arc fault, there would have to be a thermal sensor along the whole length of the conductor all the way into the TV (let's say it). Not only that, but the said sensor would have to be able to detect difference of temperatures between 3' and 5' (otherwise we're just having a glorified overload protection). That's really the only way I can see an arc fault protection working. After all the temperature where the arc takes place would be higher than the rest of the conductors. That's the way I see it, someone prove me wrong. NO "because it has been blah blah blah". Someone please show me how exactly these "AFCI's" work.
