Hi, what is the purpose of balls on transmission lines ? here is a link but i am not sure..
İs it related to the helicopters or about wind vibration or what?
Some say it has to do with wind vibration...Airplanes. Usually an airfield is nearby. Helicopters also I suppose.
Hameedulla-Ekhlas,Some say they are to warn pilots of the presence of the lines, but this
makes no sense at all. I've seen them on lines in the city, no where near
an airport, and if either fixed wing or helicopters were flying low enough
to be concerned about those lines, they've got more than the lines to
worry about. Plus, they are they spaced so far apart that their placement
would leave quite a few miles of line NOT marked to warn pilots.
1- for aircraft. It is surprising where they might be placed for
things such as a helicopter approach to a hospital or even parks where an
emergency medical pickup may be made.
2- in some areas devices (though not usually red ones) are placed
on wires that are subjected to strong winds and may fail due to harmonic
vibrations. This is usually where there is a longer stretch of wire between
poles. The goal is to dampen the vibration. Have you seen the film of the
Tacoma Narrows Bridge that ripped itself apart vibrating in a wind?
My understanding is that it is used to reduce a vibrational wind effect,
called aeolian harp, that can create resonant and even distructive
vibrations along the wire. These globes are usually placed on the wire in
windy areas or where there is a long distance between towers, and
significant sag. I have seen in most often on major transmission lines in
the plains where there is a slight rise or dip in the terrain.
Red Ball on Lines
name Todd G.
status educator
age 40s
Question - What is the purpose of the red balls you see on long
distance transmission lines?
So, what are they there for?
Todd -
First guess... for aircraft. It is surprising where they might be placed for
Second guess... in some areas devices (though not usually red ones) are placed
Just thoughts.
Larry Krengel
---Nathan A. Unterman
I've never thought about the birds. I just assumed they could see them. But I guess in mass they could get distracted.They have numerous purposes.
Some of the basics are:
Approach to runway
Where lines cross bodies of water
migratory bird travel way
The dampers for wind vibration look different. The ones we use look like two small oblong balls on opposite ends of a stick. The assembly is hung parallel to the line. I guess from the ground you could say the big balls appear about softball/basketball size but the vibration dampers would appear like peanuts/half-thumbs at arms length, relatively speaking.Some say it has to do with wind vibration...
But take the time to study and evaluate what you read. I noticed in a different thread you quoted particular excerpts from a work but did not take the time to read through to find out it was not supporting what you were saying.searching in internet and reading books for quesiton really make me to find more information and learn.
My only purpose is to learn and find.
I was trying to give the reader a perspective of what they might look like from the ground. Most of them do not get to see this stuff up close and don't realize how big (or heavy) some of it is....and, the balls are quite large. Much larger than a basketball. 24-36"dia depending...
